What size tires for a 6-ton Westendorf running gea
Jim
11-08-2003 14:28:27
I just bought a 6-ton Westendorf Gear and it needs new tires. Right now it has 14" car tires and I definitely want to replace them with implement tires. Should I go with 9.5L or 11L tires? Also, should I sty with the 14" rims or move up to 15" rims?
RWK in WI
11-10-2003 16:28:42
 Re: What size tires for a 6-ton Westendorf running in reply to Jim, 11-08-2003 14:28:27
9.5L 14 6" rim 8ply only carry 2400#
9.5L15 6" rim 8ply 2470# 12ply 3280#
11L15 8" rim 8ply 2540# 12ply 3200#
12.5L15 10" rim 8ply 3000# 14ply 4600#
Nebraska Cowman
11-08-2003 18:49:05
check tire prices for both the 9.5L 15 and 9.5L 14 and then decide. My guess is the 14s will be pricy.
T213R
11-08-2003 20:49:14
 Re: Re: What size tires for a 6-ton Westendorf run in reply to Nebraska Cowman, 11-08-2003 18:49:05
Check the load ratings for the tires. If you want six tons, your tires better have a load rating of 3000lbs each. 11.0L-15s might be too small. Perhaps you'll want 11.0L-16s
