HAYBINE
MARSHALL
11-07-2003 12:41:16
JUST BOUGHT A NEW HOLLAND 461 HAYBINE. DOES ANYONE KNOW IF A FARMALL M WILL PULL IT,AND IN WHAT GEAR. THANKS IN ADVANCE.
MARSHALL
wolfy
11-07-2003 18:56:03
 Re: HAYBINE in reply to MARSHALL, 11-07-2003 12:41:16
Second gear. All day, any day. Keep making square corners & you only touch the clutch for lunch or when the field is done.
Gary in TX
11-07-2003 18:08:13
I've pulled a 469 and a 488 New HOlland with a Massey Ferguson 135 gas tractor and had no problems at all with it. Just ate it up! I would guess hp ratings to be close to the same? Its always better in my humble opinion to pull pto equipment with a live pto tractor although it can be done otherwise.
Harold Hubbard
11-07-2003 16:56:49
I pull a Hesston 1091 (9 foot) with a Farmall M. The mower itself doesn't take that much power to run, but hauling uphill and holding it back going down works it some. I don't know what your NH weighs, but the operator's manual puts the Hesston at 3500 pounds.
old
11-07-2003 13:02:57
I have a NH 9' hay bine that I pull with an oliver 77 your M is about the same size tractor so you should be able to pull it. hope this helps
