IH #37 Disk part # needed....
FM
11-07-2003 09:44:40
I have a 9' or so #37 or #370 IH disk. I need a part number, the part, or a good sketch of the steel peice that you rotate and pin in to hold the cylinder in. Any help would be appreciated.
Mike
Leroy
11-11-2003 05:37:10
 Re: IH #37 Disk part # needed.... in reply to FM, 11-07-2003 09:44:40
My email does not want to show up, it is [email protected] for the manuals
Leroy
11-08-2003 10:07:46
The book says to (Close the cylinder latch and lock in place with a quick-attachable cotter) it is about 1/4" thick and you could just take a piece of cardboard to start, put a hole fore the pivot pin and just start cutting away till it fits in and will flop over, no longer have the disk but do have the operators manuals if interested in a copy, the 7 blade on a side is a 8' 6" if with 7" spacing, 8 blade is 9' 7" and with 9" spacing 6 blade is 9' while 7 blade is 10' 4"
Leroy
11-11-2003 05:31:39
 Re: Re: IH #37 Disk part # needed.... in reply to Leroy, 11-08-2003 10:07:46
On the owners manuals I have made many a copy for people and I charge exactly what it costs me, I have some manuals at the copy shop now and their price is. $.15 for a double sided page with state sales tax, and then postage. I have 2 versions of the manual dated 2-14-58 & 10-8-62 and they are like day and night difference, between the 2 there are 36 pages so on a double sided copy 18 x .15 = $2.70 plus tak at 7% .19= $ 2.89 plus postage. If anybody is interested email me. I do the same for any of my approx. 1,000 manuals
Tim Wafer
11-08-2003 14:52:12
I would be interested in a copy of that manual too.
Tim
FM
11-08-2003 10:38:34
Are you wanting to sell that manual? I am bidding on one on ebay but if I don't get it I would be interested in yours.
Mike
Tim Wafer
11-08-2003 09:32:49
Mike
You�re talking about just the little latch piece that flips over the pin in the cylinder? I don�t know the part # but can take it off and trace or scan it for you if you�re just trying to make an accurate copy. Pretty simple piece if I correctly understand your need. I know the guy I purchased my 56 planter from said he paid $42 for the similar part on it from a Case dealer.
Let me know if this is what you need.
Tim Wafer
FM
11-08-2003 10:36:55
 Re: Re: IH #37 Disk part # needed.... in reply to Tim Wafer, 11-08-2003 09:32:49
that is exactly what I need. A copy will do, and then I can make or have made what I need. I have the old one, but part of it is broken. I got out my trusty balin wire and made it so the cylinder would stay all the way against the latch but it looks like crap.....
Mike
Tim Wafer
11-08-2003 14:48:37
 Re: Re: Re: IH #37 Disk part # needed.... in reply to FM, 11-08-2003 10:36:55
third party image
I tried to make this close to actual size but it varies by computer so you may have to adjust it. Hope it helps!
Tim
Tim Wafer
11-08-2003 14:55:06
 Re: Re: Re: Re: IH #37 Disk part # needed.... in reply to Tim Wafer, 11-08-2003 14:48:37
Forgot to mention its 5/16" thick steel!
Hoosierbuddy
11-08-2003 04:25:30
I can email you some pictures of my 37 disc-where the cylinder attatches to the front and rear if that's what you need?
It does not have the self -leveling hitch,just the regular crank adjusterIf you mean the double tubed thing for the small cylinders,I have one.
HB
FM
11-08-2003 06:00:24
 Re: Re: IH #37 Disk part # needed.... in reply to Hoosierbuddy, 11-08-2003 04:25:30
The part I am talking about is what holds the front of the cylinder in. you pin the cylinder in the back, and then extend the cylinder forward until you can rotate this plate down and it has a hook type cutout that hlds the cylinder from going back out. it is kind of hard to explain--if you take the cylinder off and on a lot you would probably know exactly what I am talking about ;-)
Mike
