plow to use for jd 820
Richard
11-06-2003 17:41:25
I would like to know what plow to get & use to pull behind my 820? My tractor has no 3pt hitch.
MK
11-07-2003 18:18:03
 Re: plow to use for jd 820 in reply to Richard, 11-06-2003 17:41:25
I pulled a older JD 5x16 plow with my dads 830 in grain stubble. He had a good load in 3rd gear.
Bob Collins
11-07-2003 05:28:15
What JD 5020 Guy said is right but if you are looking to pull a moldboard plow, a good and correct choice would be a 777H five or even six bottom plow.
JD 5020 guy
11-06-2003 20:59:59
I assuming your 820 is a JD. Is your 820 the 2 cylinder or the newer 3 cylinder tractor. I don't know where you are at but in my area (western wheat belt) these implements would be the ones to use or show behind your 820. A 656 or 100 series chisel plow, 21ft FW disk, or a Surflex tiller will look good behind your tractor assuming it is the 2 cylinder Waterloo built tractor.
