plow types
Murl
11-05-2003 17:05:45
There are two main types of plows "I think" one is refered to as an "on land plow" what is the other type called and please explain the difference. Thanks Murl
Dan
11-06-2003 06:42:13
 Re: plow types in reply to Murl, 11-05-2003 17:05:45
Just for fun I'll throw in a couple more variations. In my area most people use 3 point plows, either total lift or as mentioned with 3 point arms on front and hydraulic lift wheel in back. Most use the roll over or 2 way plows. You pull the plow to the end of the field, raise it the roll it over to use the bottoms on the other side that roll the dirt the other way. New variation on that is a "switch" plow, instead of plow rolling over to get moundbords that go the other way you just rotate them from side to side.
Stan TN
11-05-2003 22:00:00
There are two kinds of moldboards seen around here, the standard solid and one made of strips that don't touch each other. I've heard the name, just can't remember.
Roy in UK
11-06-2003 05:36:45
 Re: Re: plow types in reply to Stan TN, 11-05-2003 22:00:00
Slatted mouldboards (moldboards) is what they are known as over here.
paul
11-05-2003 17:58:59
As the other person said, plows have picked up very regional names, so one area can be very different than another.
Here in Minnesota there is in-furrow and on-land hitches for plows. This refers the the right rear tire of the tractor (and right front if a wide-front). The tractor tire will either run in the furrow, or beside it up on-land.
A plow of 4 bottoms or less has to be in-furrow. A plow of 7 bottoms or more has to be on-land. Plows around 6 bottoms can go either way.
The tractor needs to be approximatly centered on the plow for a good pull, and a smaller plow doesn't leave room for anything but in-furrow, while a big wide plow will need dualed 4wd that doesn't fit in the furrow, and too wide for the right side of the tractor to reach the furrow.
Other major plows types: Molboard or disc (the curved metal bottom, or a giant angled disc blade); 3-point, semi-mount, or trailer (smaller plows can mount on a 3-point, mid-sized & large plows can mount on the bottom 2 arms of the tractor 3-pt plus a hyd cylinder to raise & lower the steering rear wheel, and a small to large plow that sits on 3 or more wheels of it's own & is pulled by the tractor drawbar).
--->Paul
Bigdog
11-05-2003 17:30:53
Plow terminology varies with the region. I see different names for the same piece of equipment depending on where you are. A land plow or moldboard plow - also called a turning plow in some areas has a curved flat moldboard which turns the earth over as it is pulled along. There is also a disc plow which has a rotating large disc which turns the soil over as it is pulled. There are also chisel plows which have heavy shanks with pointed shovels which break the soil up rather than turn it over.
