identification of an allis chalmer combine pull be
Rich
11-02-2003 15:58:43
how would i go about identifying an allis chalmer pull behind combine? where would i look on the machine?
Leroy
11-04-2003 18:49:34
 Re: identification of an allis chalmer combine pul in reply to Rich, 11-02-2003 15:58:43
Auger platform, 5' wide cylinder, model 72; 4' cylinder, 8' cutter bar, model 90; Canvas platform straight sides on platform, model 60; with sides that flair out a 66, early straight through model 40, a 40" cut and the selfpropelled was the model 100 with 9 or 12" auger platform; On 60 & 66 serial no. was stamped in angle iron frame on rear of machine, model no. only painted on
thurlow
11-03-2003 09:00:36
If it's got a direct-cut header, measure the cutting width; someone on here can help you from there; my understanding (may not be correct in every case) was that the width of cut (in inches) was also the model number..... ..
