Electric Wheel trailer running gear - Oliver?
David from Kans
10-31-2003 12:03:29
We have a running gear which has a hay rack on it and is marked "Oliver", but it looks exactly like the Electric Wheel running gears we have. Was it made by Electric Wheel for Oliver? Does anyone know where to get parts for Electric Wheel? It has a broken wheel hub. Thanks.
David
David from Kansas THANKS
11-01-2003 10:53:26
 Re: Electric Wheel trailer running gear - Oliver? in reply to David from Kansas, 10-31-2003 12:03:29
Thanks, everyone.
Greywolf
11-01-2003 05:53:57
If you have a willing parts store in your town, have them check into the John Day Co in Redwoodfalls, MN.
John Day has many many replacements for a lot of farm equip trailers and such. The downside is they only deal with dealers. I'm lucky, I only live 25 miles and can pick the parts up myself billed through my dealer.
If all else fails, they are worth a shot.
thurlow
11-01-2003 05:39:02
Got a Shoup catalog laying around? they stock several hubs, matched by the numbers cast on back.....
IanC
10-31-2003 18:14:27
Call Baum Bearing Company in Omaha, 800-228-9222. We used to use these guys after after the Electric wheel stuff started getting scarce. Oliver used the Electric model number as their model number (5026, etc.). Look on the back of your hubs, there will be a number cast into it, probably starting with a "Q" that will help them get you the correct stuff, as some models used two or more different hubs.
Tim(nj)
10-31-2003 17:05:13
Electric made running gears for Oliver and Allis-Chalmers.
JWC
10-31-2003 13:21:10
It is a bit vague when you say a broken hub. Do you mean bad bearings, a broken flange on the hub or is the spindle also damaged? If it is just bearings most NAPA or other major auto parts store should be able to match the parts. You might need to remove one of the good hubs so that they can match to undamaged parts. One answer is to purchase a stub axle assembly which would include a new spindle, bearings and hub and replace the entire assembly. That option might not apply if it is a front hub on an automotive type steering unit. I have three electric wagons with fifth-wheel type steering they all have 5 lugs on a 5.5" circle. The old JEEP CJ wheels will fit these hubs.
