TRACTOR PICTURES
JR
10-31-2003 03:54:11
HERE IS SOME PICTURES OF OLD TRACTORS
Jim.UT
10-31-2003 16:18:45
 Re: TRACTOR PICTURES in reply to JR, 10-31-2003 03:54:11
third party image
Tell me more about this F250 with dual rear axles. Looks like an interesting modification. Are both rear axles driven or is one of them just along for the ride (and to carry weight)?
Joel Harman
11-01-2003 15:05:02
 Re: Re: TRACTOR PICTURES in reply to Jim.UT, 10-31-2003 16:18:45
I bet the back one is a tag axle.
CASE38MAN
11-01-2003 17:41:43
 Re: Re: Re: TRACTOR PICTURES in reply to Joel Harman, 11-01-2003 15:05:02
OK YOU LOST YOUR BET. IT HAS A 200HP TRBOCHARGED AFTERCOOLED PERKINS DIESEL.IT A VEHECLER ENGINE THAT I BOUGH BRAND NEW,ALREADY SET UP FOR ALLISION AUTO, I PUT AT 545 ALLISION AUTO,IN IT AND IT HAS A BROWNLEE 3 SPD BEHIND THAT. IT ALSO HAS A ROCKWELL 223 TRANSFERCASE. IT IS, ALL LIVE AND HAS 16 WORKING UJOINTS,THERE ARE 2 BETWEEN MAIN TRANS AND AUX THAT ARE 1480, AND 2 BETWEEN AUX AND TRANSFER CASE ALSO 1480,(F-800 FORD).IT HAS 2 COMPLETE DRIVE LINES FROM TRANSFER CASE TO REAR ENDS.ALL OF THESE ARE 1410 U JOINTS.I TOOK THE BRAKE OFF THE TRANSFER AND MATED COMPANION FLANGE TO IT TO ACCEPT DRIVE SHAFT TO FRONT REAR.NO 2 DRIVESHAFT FROM ORIGIONAL POSITION TO BACK REAR THROUGH A CARRIER BERING MOUNTED TO FRONT REAR.BOTH REARS ARE OFFSET, FRONT TO RIGHT AND BACK TO THE LEFT.MADE SHAFTS LINE UP PERFECT. I HAD TO USE A CHEVY FRONT BECAUSE OF TRANSFER CASE,SO I BUILT DISC BRAKES FOR THE REAR USING ALL CHEVY 1 TON CALIPERS AND PADS.HAD TO PUT BIGGER MASTER CYLENDER (1 3/8 PISTON) WITH HYDRA BOOST. UNBLEVIBLE STOPPING POWER, WILL LOCK ALL 10 WHEELS NOW. THE BED IS 12 FEET LONG RIDES REAL GOOD. LET ME TELL YOU THAT IT IS A LITTLE WORK HORSE TOO, IT CATCHES MORE EYES THAN THAT JD DOES. JACK
avani
02-23-2004 01:56:42
 Re: Re: Re: Re: TRACTOR PICTURES in reply to CASE38MAN, 11-01-2003 17:41:43
Massey Fergusan model 245, 135, 165, 185
JR
10-31-2003 16:31:07
E-MAIL [email protected] AND TELL HIM YOU SAW IT ON CASE38MAN WEB SITE. THANKS JR
Farmall_Nut
10-31-2003 10:11:32
Thanks JR you have taken some nice pics. The B Farmall pics are to be treasured for sure!!
Nebraska Cowman
10-31-2003 04:03:29
thanks jr
