Hay Rack Plans
TW
10-30-2003 04:26:22
I want to rebuild my hayrack this winter. Does anyone have a set of plans? This is a flat rack, not for thrower bales. THanks
larry
11-02-2003 07:37:28
 Re: Hay Rack Plans in reply to TW, 10-30-2003 04:26:22
if you build one place boards with rough side up had one with smooth boards and baleing on side hill was a chalenge as they would try and slide off. also cheater board on side is helpfull 1x4 nailed length wise not sure maybe somebody can answer this if screws rather then nails would be better
BFarr
10-31-2003 04:09:55
This item has been discussed in detail with some great suggestions. I think a search under "hay wagon" may give results
TomH
10-30-2003 16:38:33
I doubt anybody works from plans. Just make it look strong enough and it'll be fine.
