M-H Disc Parts Needed
Stan Presley
10-29-2003 19:29:32
I have an old Massey-Harris tandem three point disc, about a 6 footer, in need of a complete left rear gang. Any suggestions where such a thing might be available for sale, or possibly where parts to build up a new one could be purchased?
Hal
11-01-2003 05:35:16
 Re: M-H Disc Parts Needed in reply to Stan Presley, 10-29-2003 19:29:32
Stan- When you say you need a complete gang, what is missing? Are the hangers there that bolt to the top bearing caps, or do you just have the frame with the ball joints that connect to the hangers?
Do the remaining disk gangs have white metal or wooden bearings? All of these parts are available via Agco but are VERY pricey. You could probably get a bolt from Shoup, but is a 7/8" bolt. I would first look for another disk for some of the parts. I believe a lot of these disks had a 6.5" spacing, which does a smooth job but is kind of non-standard.
Before you do anything, check out the condition of the bearings etc. on the remaining 3 gangs. If they also need work you will be looking at too much expense. I have one of these disks and the next repair I will look at modifying it with 4 new gangs that use modern ball bearings and cheaper parts (JD?) that attach to the original ball joint hangers via some kind of fabricated adapter.
js
10-30-2003 10:04:11
you might try one of the mail order places, like agri-supply.
John K
10-30-2003 07:29:14
I just bought parts for a mh-62 3 bottom 3 point hitch plow at the local Massey Ferguson dealer. He had different equip listings for MH. I ordered plow shears there, couldn't find any where else.
