Sickle bar mower
Wayne
07-10-1999 07:42:28
I have a Farmall H and I am looking at a New Holland sickle bar mower model 455. It is in good shape and appears it will do the job. However I do not know anything about these type mowers. My field is level. They are asking 350.00. I do not have a 3 point hitch so I need to get something that has a drawbar type hookup. Any help would be appreciated. Thank you.
Paul Fox
07-10-1999 16:06:18
 Re: Sickle bar mower in reply to Wayne, 07-10-1999 07:42:28
I am climbing a VERY steep learning curve on sicklebar mowers myself. I have an Allis-Chalmers #3 that I rebuilt over the winter. I completely rebuilt the cutterbar with new knives and ledger plates. My first attempt to cut with it was just pitiful. After three evenings of try this and cut a little, try that and cut a little, try something else and cuss, er, I mean, cut a little, I've gotten it so it cuts pretty well.
Tips: 1. Knife register (or timing) is critical. At the extreme ends of the stroke, the knives MUST be centered on the guards. This means CENTERED, not a quarter-inch one way or the other. 'Bout drove me nuts 'til I realized that.
2. Bar "lead" is very important. The bar must be set up so that the outer end "leads" the inner end at rest. When moving, the load on the bar will pull it back a bit, and you want it to be square with the tractor when cutting.
3. The bar must be reasonably level when in the cutting position. On older machines, the shoes on the inner and outer end of the bar are frequently worn out, and bits of this and that (leaf spring works well) have been welded on as replacements. Mine was way too low on the outer end, causing it to plug, dig in, and trip the "break-back" that keeps you from tearing the bar off the mower.
If you get it set up right, I think you'll find it'll do a nice job for ya. Good luck!
OCB
07-10-1999 09:15:11
The advantage of a sickle bar is low power required and speed of cutting if free of trash. I'm not familair with the NH mower, as I recall everyone liked the New Idea trailer mower . Many mowers have brackets to cross from one manufacturer to another.
One point of SAFETY is never put your fingers between the sickle and guards. When picking up the Bar for transporation especially handle the bar from the trailing edge as the sickle will slip down cutting.
