tractor size for bush mowing
Guy
10-27-2003 19:47:22
Hey folks, I want reclaime some pasture and have to bush hog or flail mow the eges or my 40 acre
pasture but I would like to use older low HP tractors Ford 9N or something of that nature.Is this reasonable? Have I lost my mined...again.
Thanks
Guy
Stan TN
10-27-2003 23:59:13
 Re: tractor size for bush mowing in reply to Guy, 10-27-2003 19:47:22
Unless you have a 9N you'd be better off with an 8N or even a Jubilee.
R. Marg
10-27-2003 19:59:51
a 9N will do the job as long as you use a 5ft or so brush hog
INCase
10-28-2003 10:44:43
 Re: Re: tractor size for bush mowing in reply to R. Marg, 10-27-2003 19:59:51
we use a 9N w/5ft wood brushhog and 5ft wood mower (finish) . works but can't take a lot of abuse like cutting up small trees, (I've bought a newer 57hp Case to do the heavy stuff with). and its a bit light, which has advantages and disadvant. I've been amazed at what I've been able to do with it though. An 8N or newer with more gear choices would be better. Advantage of little fords is they are common as grass so parts are available. downside is they are over priced for what you get. You can get a "decent" 20 year newer, 45hp Allis Chalmers or Case for about the same or less money. shop around, ask around. check out auto-rv.com and click on the farm tab and pick your brand too...
