Ford 530 Hay Baler
SASHANE
10-27-2003 19:02:15
G'day,
I was wondering if anyone could tell me the thickness of the guage washers on the PTO clutch on the Ford 530 Baler. My manual doen't have the size and my baler doesn't have the washers.
Thanks.
Jerry D in NC
10-28-2003 03:19:02
 Re: Ford 530 Hay Baler in reply to SASHANE, 10-27-2003 19:02:15
Shane, They are just a normal flat washer. Pull the springs down till the washer don't move and back them off until the washer just is loose between the spring and the drive face. If you don't have them then I would go ahead and check at least the front two clutch discs to see if they are in good shape while you are taking the springs off to put washers on. The washers may have been taken off by a previous owner to compensate for a overly worn clutch disc.
norbert kanzler
10-27-2003 21:31:43
Go to your Ford New Holland dealer he either stocks them or can order to parts I have a Ford 530 and my dealer can get everything
