Hugh MacKay-plowing question
John51
10-27-2003 09:56:54
I found your comments on plowing using a chain or wire to push loose material under quite interesting. You say you've plowed cornstalks that way. Did you disk or chop them first? I find that in a good year disking doesn't work for me (too many stones and hard clay) and cutting the stalks is slow and expensive. Please tell me how you do it. Thanks, John
Hugh MacKay
10-29-2003 17:48:22
 Re: Hugh MacKay-plowing question in reply to John51, 10-27-2003 09:56:54
John: Take the corn stalks just as they are from the combine, no disking, no shredding, etc. The chain or wire is hooked just to right of coulter and allowed to pull under the furrow that is being turned. You need a chain for each furrow. The plow I used was an IH 510 5x16 plow, not a big clearence plow. You need chain long enough so about 2 feet is pulling under furrow, this keeps chain tight thus pulling the stalks right under. One of the best uses of a few dollars I ever got in my life.
