477 newholland haybine
RICK
10-26-2003 08:15:31
i got a 477 haybine i got from a neighbor the gear box was already off of it because the bushing on the hub got worn out and started slipping on the main gear box shaft.well i got everything repaired and put back together. but i need to know how much play from side to side the overiding clutch should have. i think you adjust this by sliding the beltpulley one way or the other.
Steve from New Holland
10-27-2003 04:46:06
 Re: 477 newholland haybine in reply to RICK, 10-26-2003 08:15:31
Rick, the overrunning clutch should have zero play side to side. However, if you are using a tractor with live pto, (and you probably are) please weld the 2 pieces together and eliminate the clutch. They cause more trouble than they are worth. However, if you are using an old tractor without live pto, do not weld together. Steve
RICK
10-28-2003 16:02:57
 Re: Re: 477 newholland haybine in reply to Steve from New Holland, 10-27-2003 04:46:06
steve exactly where do i weld them together at
thank you RICK
