Plowing
Nathan
10-24-2003 19:07:49
I have been trying to plow up some sod recently with a 3 bottom, 3-point plow. I am having problems with the plow jamming up with dirt and debris. Is there something that I may not have set up right? I have mowed the grass down short. How close should the cutter be to the plow?
Thanks for any help
Hugh MacKay
10-25-2003 02:20:24
 Re: Plowing in reply to Nathan, 10-24-2003 19:07:49
Nathan: Paul is correct, if debeis on surface is long, much better if attached to ground at one end. One of the old rules plowing down corn stalks, either shred them to bits or don't touch them after combine. Good, well adjusted coulters very important.
paul
10-24-2003 22:14:37
Sounds like it is muck type soil, and your plow isn't shiny yet? When you ay you mowed the grass - is it chopped up into little bits, or was it sickle mowed & is long big stems now loose on the surface? Many times it plows better if you don't mow it, altho brush hogged into little bits should work ok.
Usually the coulters should be fairly close to the bottom. Are they nice, big, I said big, coultors, or worn down 2" at which point they don't do much?
--->Paul
