city boy trying to learn about the country
Jerry Wallen
10-23-2003 15:56:07
When measuring a bottom plow which way do you measeure to determine its size? I am looking for 2 -14's and want to be sure I get the correct size--thanks Jerry
Leroy
10-24-2003 18:43:39
 Re: city boy trying to learn about the country in reply to Jerry Wallen, 10-23-2003 15:56:07
What he says will work for most plows but not for a JD No. 44 plow, that plow is made in a small frame, adjustable 12" or 14" by turning the shanks around and that frame will measure 13", the large frame same way for 14" or 16" and will measure 15"
jim
10-23-2003 17:19:25
Jerry - Very simple, measure the distance(centre to centre) between the plow beams. For example, the 2 furrow 14" plow you are looking for will measure 14" between the beams. Beams are what the mouldboards are attached to.
