Home made Bush Hog?
David
10-23-2003 11:37:33
Has any one made one? Where can you find a heavy duty gear box and stump jumper? The remainder looks like ordinary steel and a lot of welding.
Ultradog MN
10-24-2003 14:49:41
 Re: Home made Bush Hog? in reply to David , 10-23-2003 11:37:33
A couple years ago there was an interesting thread here that talked about building your own brush hog type mower.
Someone from Texas told about how down there folks would take the rear axle out of an old truck, turn it so the pinion was facing downward and attach some mower blades to it.
They would add some guards and a frame to pull it with. It wouldn't be much good in tight spots where you had to go real slow but out in the open where you could get a little speed up I think it would do a pretty good job.
Best part about it is it would be very cheap to build.
Good luck
rustyfarmall
10-24-2003 12:33:14
If you go out and price all of the parts it will take to build one, including the steel, I think you will find that it would be less expensive to buy a decent used one, and a whole lot less hassle.
treeboy
10-23-2003 17:49:42
if ya got a nice shop & like welding: buy an old fixerupper thats rusted out the deck, gearboxes cost money, but sheet metal and angle steel is about it, ya better have a good impack whench & torch also..
