 I need this nice an simple boys! I have a #8 2 bottom IHC plow. Its been hooked up and I have cut a bit of ground. I bought a operators manual for it on e-bay. There are two long adjusting levers on this plow, pretty much like all other plows I see in your guys pictures. My manual does not even whisper about these two main levers. In general terms, what do these levers each do? I will give you a scenerio on flat ground, when I make my first past in the field, the furrow falls back over. Quite depressing. I have to assume that its linked to these arms. So my wife and I go out with shovels, break the thing into pieces and manually roll it over so that I can get into the furrow with the wheels. Once I can run in the furrow, its fine. Text book, nice plowing. I dont want to do too many test runs and fail because what a mess. I think that its properly adjusted on the hitch as per the manual. So when looking from the hitch end, there is the left lever and the right lever. Can we go over that? If you can believe it, she doesnt want to manually turn the first row over anymore and I want to cut a large area open. I dont know whats wrong with her.
