what size disk?
Deamer
10-21-2003 13:06:40
This question from a "newbie" so go easy on me fellows. My question is how do I find out how much disk my tractor will pull. I have a IH 656 hydrostatic gas with a 291 engine. I don't want to buy a disk and then find out it's too big for the tractor. So how do I find out? I'm wondering if it will/should pull a 14 foot disk?
Deamer
11-18-2003 15:38:17
 Re: what size disk? in reply to Deamer, 10-21-2003 13:06:40
I appreciate the input from everyone. I have a ten foot IH that needs some blades replaced. I think I'll do that and use it. Thanks again.
Deamer
rustyfarmall
10-21-2003 17:28:19
Don't know where you live, or what soil conditions you have, but here in S.W. Iowa the 656 would be a perfect match to a 14ft. tandem disk.
Tim(nj)
10-21-2003 18:19:57
 Re: Re: what size disk? in reply to rustyfarmall, 10-21-2003 17:28:19
Also depends on the weight of the disk and the size of the blades (the bigger the blade the deeper you go). I have a 10' Taylor-Way tandem disk that your 656 would not be able to budge in plowed ground if you let it down all the way. I also have a 10' JD KBA that your 656 wouldn't even know was behind it. The Taylor-Way has 24" blades and is an immense bulk of steel, while the JD has 20" blades and is fairly light in construction.
paul
10-21-2003 16:19:47
Are you figuring the 'typical' tandem wheel disk, for secondary tillage purposes? So often I give an answer, & find out the guy wanted to pull an offset disk for digging up sod in one pass! Oops! :)
In softer spring condions, a 14' will give it a good pull. In firm fall conditions that are dry, like disking cornstalks, you could use about any gear you want.... In my type of ground for what I do, a 12-14' tandom wheel disk would seem about right.
--->Paul
