Hay Rake Teeth and baler pickup tines
Scott(MO)
10-18-2003 22:53:55
Hello, I'm looking for a good aftermarket dealer who sells rake teeth for a Farmhand Model F76-E M25 Wheel Rake. I can get them from the New Holland Dealer but they seem a little high to me . Also, I need to find a good supplier of baler pickup tines for Oliver 620 baler. Someone awhile back on here give me info on some but I misplaced the address. Thanks in advance.
Scott
Don-Wi
10-22-2003 20:41:26
 Re: Hay Rake Teeth and baler pickup tines in reply to Scott(MO), 10-18-2003 22:53:55
W've bought out fleet farm's rake teeth a couple times to replace all the busted ones, says it's made by morril, but same thing as a farm hand. Fleet Farm is similar to farm & fleet and other farm supply stores in your area. Cost up here is about $1.75-$2 per tooth. I think I could also find a similar pick up tooth for what your baler needs as well. Just have to look in the right places.
Donovan from Wisconsin
Dale in IN
10-19-2003 10:38:49
Tractor Supply has the teeth for the Farm Hand 76.Off hand I think about $1.88 @
paul
10-19-2003 08:23:24
Shoup probably has something that matches. I may have told you it was shoupparts.com
They have double rubber mounted wheel rake teeth for Farmhand $5.05, is that it? There are many other styles listed with diagrams in the catalog.
--->Paul
Scott(MO)
10-19-2003 13:25:07
 Re: Re: Hay Rake Teeth and baler pickup tines in reply to paul, 10-19-2003 08:23:24
I don't think that's the one , but I will look them up and see what they got. Thanks .
Scott
Dann
10-19-2003 05:53:18
Scott I have a farm hand 5 wheel rake that you pull and the big wheels turn by rolling on the ground its has 2 transport wheels and is painted green and yellow. It takes Pollard rake teeth that uses a 3/8" carriage bolt to hold teeth to the wheel. If this is what you have Falder's farm store in Princeton Ky has them for $1.50 each. Hopes this helps you.
Scott(MO)
10-19-2003 13:33:30
 Re: Re: Hay Rake Teeth and baler pickup tines in reply to Dann, 10-19-2003 05:53:18
Thanks Dann, Mine isn't green and yellow but it sounds like the same rake. I will check Falders store. Thanks a bunch!
Scott
Ernie
10-19-2003 18:44:10
 Re: Re: Re: Hay Rake Teeth and baler pickup tines in reply to Scott(MO), 10-19-2003 13:33:30
Scott that is the brand hay rake that Tractor Supplies sells they have the parts for Farmhand
