What is this part called on JD FBB drill??
FM
10-16-2003 06:43:50
On my FBB, the cast iron part of the opener that runs in the dirt beside the disk has broken on 4 of them. It has single disk openers. I would like to find four or 6 of these cast iron boots or whatever they are called to fix it but don't know what to call them. Other than that the drill works pretty good. 2 of these cast iron parts have broken off at the top and 2 of them have the scrapers broken off of them. Without the scrapers they plug quickly with stalks.
TIA
Mike
Tom
10-16-2003 21:41:16
 Re: What is this part called on JD FBB drill?? in reply to FM, 10-16-2003 06:43:50
Way too many variations of the boot to give you all the part numbers here. I bought a JD Parts Catalog through JD for a very reasonalbe price.
RayP(MI)
10-16-2003 17:50:50
I had a couple broken off on a drill we picked up. Ground off the broken edges to form a "V" where the pieces went together, and welded them with a wire welder. They've held OK so far. Am going to make a couple of scrapers out of scrap metal and weld them on where they are missing before next season.
Rob
10-16-2003 08:36:20
You're right - Boot. They come in both left & right hand as well as long, short, and wait for it - "semi-deep"!!. I have JD Part #'s if you need them. HTH.
FM
10-16-2003 09:45:19
 Re: Re: What is this part called on JD FBB drill?? in reply to Rob, 10-16-2003 08:36:20
thanks soo much. any idea on how to tell if I have a long, short, or semi deep? Will they have the numbers cast into them? My equipment is 50 miles away so I can't go out and look.
Mike
Rob
10-16-2003 12:32:38
 Re: Re: Re: What is this part called on JD FBB dri in reply to FM, 10-16-2003 09:45:19
Not a clue! I run a B-A drill with double disk openers. The only reason I knew about your drill is all styles of JD end wheel drills are in the same manual and parts catlog. I also discovered there's two types of boots in your case, hard iron & anti - friction bearings just to confuse the issue even more! Just a guess but there's a good chance they have casting #'s - a lot of JD parts do. If you get the number, I could cross-reference it with the parts catalog. HTH.
Tim(nj)
10-16-2003 13:07:22
 Re: Re: Re: Re: What is this part called on JD FBB in reply to Rob, 10-16-2003 12:32:38
They do indeed have casting numbers. You can use the later style boot on your drill, but you have to use a disk that has the right bearing in it.
