CASE plow parts
bustedknuckles
10-15-2003 17:31:07
I have an old CASE 3x14 plow, hydraulic lift with a trip beam. I need a part for the plow that in the book is called a retainer. This piece sits on top of the beam and holds a heavy spring with a set screw on top that is tightened or loosened to adjust the tension on the spring. This spring allows the bottom to kick out if it hits a rock. The piece I need has a casting number of T1503. I was told by a dealer that the plow is a Model MTA. Does anyone know where there is a parted out plow like this or where I could inquire about parts. I appreciate any help.
Tim(nj)
10-16-2003 13:17:56
 Re: CASE plow parts in reply to bustedknuckles, 10-15-2003 17:31:07
I am assuming CaseIH no longer has the part?
Try www.buyag.com. Since you have the part number, the locator might find one for you.
MAD DUC
10-16-2003 03:04:15
Good luck. I was also looking for that same part for my 3x16 EXC plow. Can't seem to find many parts or info on this plow. Ended up having my part weled back together, and it works fine.
