Dethatcher
Rick A
10-12-2003 16:28:23
I was wondering if anybody knew of a manufacturer that made a large (5-6ft) dethatching rake similar to the little ones you see at Home Depot, Fleet Farm, etc. that are made by Brinly or Agri-Fab. I need to dethatch about 5-6 acres of lawn and want to pull a larger tool behind my 8n or jubilee and don't want to waste time pulling one of the $39.99 versions! I have a 6ft Land Pride landscape rake but that would not only dethatch but "delawn" as well. Would a drag harrow like the ones that Northern Tool sells work?
david stephenson
10-16-2003 15:58:56
 Re: Dethatcher in reply to Rick A, 10-12-2003 16:28:23
try www.edneyco.com they are in the dakatos and dealer for the little 4 wheel estate rake and landscape rakes i am going to buy twoof the 4 wheelrakes next year to help me in the fall to cleanup grass and leaves, my 2 cents worth
david stehenson
10-13-2003 07:28:16
there is a company in south dakato that makes a 4 wheel estate rakes that two can be put together for what you are trying to due if i can find their address i will post it later today as i just got off work.
Roy in UK
10-13-2003 05:04:10
Opico, which I believe is an American company, market a rake for grass harrowing and weeding cereals here in UK, although it does not appear in the US website!
http://www.opico.co.uk/agmac/grass-harrow/
Jerry D in NC
10-12-2003 17:38:10
I know this will sound crazy but a 4 wheel hay rake does a great job of dethatching. The rake works by dragging it on the ground and it works great. I use it alot in the spring to dethatch and scratch the ground so I can add a bit of seed to thicken a lawn. Just a thought and you might be able to pick one up cheap at the end of the hay season. They sell new for less than $500 so keep that in mind as you find other implements. Might be able to find a friend that does hay that will let you borrow one to try or go to a dealer and see if they have one that they would rent or loan for the day.
charlie
10-12-2003 16:37:08
check out jrcoinc.com.
