international 430 baler problem
havvey
10-11-2003 13:04:18
My inboard knotter is plugging up at 75-100 bales with the cut off twine, clean it out its fine. What is wrong with it, done it for quite awhile; I have put new knives in and use the green twine
JB
10-12-2003 14:12:12
 Re: international 430 baler problem in reply to havvey, 10-11-2003 13:04:18
Hi, are these twine fibers that are 2 inches long?
Is it an 'all twine knotter'? Is the twine thicker than normal? Could be that twine disk requires adjustment. If the twine disk is too tight it will shave fibers off the twine. I can't remember if you had to add shims or if it was a spring tension adjustment on the 430. I remember the 46 you had to add or remove shims from the twine disk. My brother has a 430 all twine knotter and he perfers to use black poly twine in it.
Good luck
JB
havvey
10-12-2003 14:33:09
 Re: Re: international 430 baler problem in reply to JB, 10-12-2003 14:12:12
it is a twine disc but dont know if its all twine yes twine pieces wind up in the knotter the twine i use is the green 9000
JB
10-12-2003 16:31:16
 Re: Re: Re: international 430 baler problem in reply to havvey, 10-12-2003 14:33:09
If it is an all twine knotter, I seem to remember that it is an adjustment nut with a spring on it.
One adjustment is for the bill hook and the other is for the tension on the twine in the twine disk. Consult the Operators manual. Make sure the twine knife is sharp and adjusted properly before attempting any other adjustment.
Other hints: compare the 2 knotters as for adjustments. If you decide to make any adjustment make sure you record the original setting so if adjustment causes some other problem it can be returned to previous setting easily. Never turn adjustment more than 2 turns at once.
Good luck
JB
