Thanks!!!!
Jim
10-06-2003 17:09:37
Way back on page 12 of this forum I asked for help on a problem I was having with an old two disk plow and I was advised to seek help from a knowledgeable welding or machine shop in the area. Well....believe it or not....but when I walked in the door of the machine shop the elderly gentleman behind the welding mask turned out to not only be a veritable gold mine of plow information but also one really handy fella with a welder! I learned my plow is called an Alamo Plow.....its a 28" disk plow and came in individual disk segments such that the segments could be bolted one behind the other to make it as long and as wide as you thought your tractor could handle...and ended in a land slide furrow wheel segment to keep all of it and the tractor headed in a straight line! The individual segments of the frame have adjustments to gauge the depth and width of the cut. When I handed this guy my worn out disk axle.....know what he said? "I'll have it ready in 30 minutes if you wanna just wait young man!" And then to top it all off....he made me help...so as he put it....next time I could just do it myself!!!!
Basically what he did....was this...first...he pressed the axle back into the hub I had removed it from thinking it was a throw away part. Then he put it on a metal lathe and proceeded to weld longitudinal beads along the area of the nut threads. He built it up this way until it was large enough that he could use the metal cutter of the lathe to turn it back down to a standard size from which he could cut new threads into the welded material. He figured we'd go up one size so as not to recut the threads (and the welding) back too close to the original layer of the shaft. He dunked it in a bath of oil.....then soapy water....and finally back on the lathe and polished it all up with steel wool till I swear to God....it had to have looked better then any store bought replacement could ever have looked. He handed it to me for inpection.... and said....there ya go, fella.....that'll be $12.50!! I like to died!! I handed him a twenty and felt like I had cheated him outta half of his kids inheritance!!!! Sooooo o..... the moral of this story is this.....when all else fails...and you have no where else to turn....you can't go wrong following the advice on this board....and you sure as heck can't gp wrong at your local machine shop!!!!! ! Thanks everyone for the help....Plow ON!
Don-WI
10-06-2003 20:22:52
 Re: Thanks!!!! in reply to Jim, 10-06-2003 17:09:37
Glad to hear it!! I myself work at a small machine shop where we do alot of this type of work, and most farmers are glad to do it that way. We also make LOTS of sprockets, make replacement parts for AGCO, new parts for assmbly for Meyers, Gruetts, Artic cat, etc... We can cut almost any gear, sprocket, you name it. We can also be flexable at times.
Donovan from Wisconsin
