Ag tires would be better for plowing esp. Older tractors were built more for plowing, you could adjust the tread width of the tractor and such. The problem with the tractor pulling to one side is that the plow draft is to one side. I think on the newer tractors like you have wheel tread adjustment is not recommended, but lining things up so the plow is pulling closer to center on the tractor (but you still need the plow to follow correctly so the tire of the tractor goes in the furrow) the more naturally it plows. Can we assume this is a 3-point plow? Are you letting the 3-point arms sway side-to-side? It's better to _not_ use sway bars or chains with a plow. Then set up the plow so it pulls about in the middle, not slid all the way to one side or the other. Perhaps your landsides are worn out. Or you need to adjust the angle of your plow - not up/down, or tilt, but left/right angle. When set up right, without sway bars the plow will foolow the middle of the tractor, and everything lines up about straight - most of the time. You have your plow clean & shiny by now? A rusty/ dirty molboard will be impossible to set up, get it shiny. --->Paul
