PTO WOES
Steve in Oregon
07-06-1999 16:06:20
I just got a MF 4850 Rototiller at auction to work behind my little old Massey. It's a 4 ft tiller and has a small pto coupling with no appearant shear pin or slip clutch. It came with a standard size PTO shaft which has a converter inside the female end that goes to the tiller. Am I missing something? I don't want to run it without a shear pin. Any ideas on how operate the tiller without ruining my PTO. Thanks for your help!
C.C.
07-06-1999 17:16:28
 Re: PTO WOES in reply to Steve in Oregon, 07-06-1999 16:06:20
Steve,
I'm not real familar with that exact setup, but they do sell slip-clucthes for bush-hogs and such. I would imagine that the same thing would work for you. Best advice, take the pto setup to a dealer and see what they say. Hope this helps. Casey
Paul Fox
07-07-1999 07:17:11
 Re: Re: PTO WOES in reply to C.C., 07-06-1999 17:16:28
Check to see if there is a slip clutch between the PTO shaft and the gearbox on the tiller. If there is, and it's ajusted properly and cleaned, you're good to go.
