pto driven dump body tailor
farmallsc
10-01-2003 15:41:52
i have an old trailor, it was pulled by a super c and it has a dump body, in addtion to the hitch there is a square metal bar which a pto sleeve fits on, the wheels are double like on a one ton truck and there are only tires on the outer wheels, no make or model anybody have an idea?
farmallsc
10-02-2003 14:18:29
 Re: pto driven dump body tailor in reply to farmallsc, 10-01-2003 15:41:52
yah it might be the back of a dump druck, because the axel looks like it has spider gears inside maybe they put a cap where the shaft went it? the pto drives the dumper not the wheels but the dumper doesnt look hydraulic there may be hoses but i couldnt see them (its sunk into the ground about 6 inches) anyway if its not IH i might weight to restore since its full of rocks
Jerry D in NC
10-02-2003 08:19:55
It wouldn't be an old dump truck someone cut the frame and made a hitch on would it. That happens around here rather frequently. Get one the motor is dead on and it needs a bunch of work, then cut the frame and keep the pump on it and use the Tractors PTO to power the hydraulics and off you go. Set it up properly and you can have a good dump trailer that costs you $10 to tag each year and doesn't have to have insurance instead of $200+ for 20000lbs tags and pull it with the truck you already have the weight tags on and hitch the tractor to it when you want to dump.
JDK
10-01-2003 20:09:51
Does the PTO run the dump mechanism,or does it drive the wheels?Might be/or be made from,an old "grain cart".PTO drives wheels at a speed to appx match one of the tractors lower gears.There were also homegrown pulpwood trailers made this way yrs ago,which later turned into the modern "forwarder" used by modern loggers.
