John Deere Model 272 Plow
John
09-29-2003 11:24:45
I have a JD one-bottom riding plow that has "John Deere 272" stamped on the main beam. Where can I find the serial number?
How old is it and how much might it be worth? It seems to have all parts in tact. The three wheels turm but the two handles don't move.
Thanks for any info you can provide>
Bob Collins
09-29-2003 12:44:05
 Re: John Deere Model 272 Plow in reply to John, 09-29-2003 11:24:45
John, The plow that used the beam number 272 was the New Deere Sulky built from 1903 thru 1940. Plows with the same name built from 1903 thru 1930 appear to have used a different beam number for the light weight version and 272 for the heavier one. After 1930 they all used the heavier #272 beam. There is no serial number on a plow and most often there is not even a model number, hence we have to start with beam numbers and go from there. Value is always between buyer and seller, start high and reduce if you are selling, start low and raise if you want to buy. Bob
