Planting Pumkins
Kip
09-28-2003 21:16:28
I am planning on planting several acres of pumpkins next year I have a one row JD 71 flexi planter with a single point fast hitch to use behind my IH 140 can this planter be set up to plant pumpkins can you get a seed plate for pumpkins it has several spare sprockets stored in the drive chain housing can it be slowed down enough for wide seed spacing the planter has double disks openers and the narrow smooth press wheel ALL ADVICE would help Thanks Kip
alyse and joey-lynn
06-14-2005 06:49:03
 Re: Planting Pumkins in reply to Kip, 09-28-2003 21:16:28
youarebad
JS
09-30-2003 16:49:54
My John deere 290 , lists settings for planting pumkins at 36" in it's manual. For plates I would suggest Lincoln Ag . I think this is the web site www.lincolnagplastic.com
JS
09-30-2003 16:55:10
 Re: Re: Planting Pumkins in reply to JS, 09-30-2003 16:49:54
sorry the correct web site is www.lincolnagproducts.com
mitch
09-29-2003 19:52:11
i used a john deere 1 row planter last year and used a 12 cell plate, did good, still had to do a little thinning though
mitch
Tim(nj)
09-29-2003 13:39:25
You can get a blank plate to cut your own notches in. You can also fill some notches in an existing plate with epoxy body filler and then sand it smooth, to get the desired spacing.
