NH 271 hayliner outer tire
ChrisL
09-28-2003 20:58:18
We just got a old new New Holland 271 hayliner - it has a new 5.7x15" farm implement tire on the outer edge by the pickup - BUT in the raised postion all is OK, but when you put the pickup lower the main shaft running through the pickup rubs on the outer edge of the tire...
don't know if all 271s have the little rope deal connected to the outer wheel to make the swinging tongue work or not but this one has that - everything seems straight and not bent and in proper placement....
ANY good ideas out there?
Ty
09-30-2003 04:49:21
 Re: NH 271 hayliner outer tire in reply to ChrisL, 09-28-2003 20:58:18
If the rim is dished can it flip around?? It's been awhile since I was by one.
paul
09-29-2003 19:01:17
You all got me curious enough to pull out the parts manual (NH270/271):
LH tire is 6:40x15 6 ply original
RH tire is 5:00x15 4 ply original
In short, the solution is to get a skinnier tire.
--->Paul
Bill
09-29-2003 09:56:04
I can't speak for your NH, but my JD 14T has a 5.00 - 15 on the pick-up side, similar to the other's comments. My question is - where can you find a replacement that size?
Good luck,
Bill
N Puller
09-29-2003 11:08:06
 Re: Re: NH 271 hayliner outer tire in reply to Bill, 09-29-2003 09:56:04
MILLER TIRE
John Kirsch
09-29-2003 09:28:46
I also have a NH275 with a 5.00 X 15. I think your tire is too big. John in NY
N Puller
09-28-2003 22:46:16
I HAVE A 275 HAYLINER AND THE OUTER TIRE IS A 5.00.15
