hit or miss engine question
Tom A
09-27-2003 16:37:16
What does it mean when a hit or miss engine that is not under load hits almost all the time? Might go 6 or 8 pops in a row before it skips one.
I was looking at one at a tractor show today that is for sale, and that's what it was doing. Most of the ones I've watched before seem to go for quite some time between pops when they're not under load. Is this one perhaps in need of a rebuild, or is there some simpler explanation. It is an old Massey engine.
thanks,
Tom
Baggsy-Wy
09-27-2003 20:52:29
 Re: hit or miss engine question in reply to Tom A, 09-27-2003 16:37:16
Governor could be needing some work also. The weights could be sticking, or the detent isn't catching like it should. Most of these old machines are pretty simple, and you might be able to use it's 'problem' to your advantage and get him down in price a little. Should just take a little tinkering to get it running smooth...
Steve from New Holland
09-27-2003 19:32:34
Tom, I own a John Deere Model E 1and 1/2hp. Whenever I have the fuel set too lean, the engine does not get enough fuel to properly pick back up the speed that was lost when it was coasting. So when this happens, the engine just keeps firing with every compression stroke untill it does develop enough power and speed to start coasting again. All I need to do is open the fuel vale a little more to make more horsepower. Steve
