welding cast iron
Huckleberry
09-26-2003 08:29:24
I busted the yoke [it has a u-joint on either end] that runs from the center gear box to one of the lateral gear boxes on a 10 ft bush-hog. a bit expensive to replace...it is cast iron...I have all the pieces ~ but it is cast iron...any thoughts on whether it can be welded and expected to hold? I know there are some good welders but as I recall ?? welding cast requires a little extra beyond good to stand the punishment...evidently? that I enjoy inflicting upon my machine ~.
Tom
09-27-2003 20:54:56
 Re: welding cast iron in reply to Huckleberry, 09-26-2003 08:29:24
Welding yoke on PTO drive is an accident waiting to happen. Don't risk it.
Bus Driver
09-27-2003 15:43:31
All the yokes that I have identified have been cast steel. 7018 electrode would be a good choice for welding the cast steel, DC much preferred.
RJ-AZ
09-27-2003 13:54:11
Most of the yokes are cast steel and weld up pretty good. I have done it as a "get by fix" it all depends upon where it'ts broke.
horsehauler
09-27-2003 05:48:22
I have found it's best to weld cast with a 309 stainless rod. Bevel the area down and then heat it with a torch before welding. After welding it you can bury it in some lime so that it cools slow. The old cast welds much better than anything new. I have welded a lot of cast but honestly believe that in your case I would buy a new yoke due to the stress and speed you are inflicting on it. Good Luck.
Steve
09-26-2003 17:58:01
Are you sure it is cast iron, it could be cast steel and if it is it is simple to weld.
jeff
09-26-2003 17:30:36
if it were me, considering what you might damage if the weld broke going full power, i'd buy a new one. you can always get the yoke end only and attach it to your shaft. No need to buy the whole
drive shaft.
just my thoughts jeff
