I need help again
Bill in NE Texa
09-25-2003 11:57:28
I bought a JD24T at auction. I bought an owners manual and went through all of the timing. Everything looks good except for the plunger stop.After the knotter trips and the needles start the return home the plunger stop is still extended into the chamber as it should. The needles are still into the chamber about 1/2 way.I'm missing something, but don't know what it is. I was using a Ford 530 prior to this and it did not have a plunger stop.But after reading this forum It seems unwise to disconnect the plunger stop. Please help. Bill
charles
09-26-2003 00:19:39
 Re: I need help again in reply to Bill in NE Texas, 09-25-2003 11:57:28
Had the same problem with a JD baler ,just turned the flywheel backwards a little , I think to catch a sprag in the needle / plunger stop / knotter system ....try it .
larry
09-25-2003 18:36:00
this is a pure guess...is it possible your needles aren't completely in the "home" position??? this would do what you're describing....I think.
Bill in NE Texas
09-25-2003 19:05:26
 Re: Re: I need help again in reply to larry, 09-25-2003 18:36:00
Yes, They are in the home position.But beleive me, I double checked.Thanks for the feedback. Bill
Garry
09-25-2003 17:15:22
Bill,
The plunger stop is connected direct to the needle carriage (at least on my 273 & 542)..... .if the needles are not in 'home' position, the stop will/should be still extended to 'stop' the plunger full of grass from breaking the needles (if the needles/knotter assembly is/or becomes, out of 'time' with the plunger).
Garry
Bill in Ne Texas
09-25-2003 18:21:29
 Re: Re: I need help again in reply to Garry, 09-25-2003 17:15:22
Gary, That is my problem. I just can't seem to get the needles back home in time, before the plunger comes forward enough to hit the stop.It appears that everything is in time,but will check the knotter timing again.I also don't know if the plunger stop rod is supposed to be perfectley straight or if it was bent when the needles were broken. This baler I bought at auction and haven't used it yet. Bill
Garry
09-25-2003 22:47:28
 Re: Re: Re: I need help again in reply to Bill in Ne Texas, 09-25-2003 18:21:29
Bill,
A statement, question, & a short story for clarification..... ...
'forward' = toward the front of the baler but is actually the 'backside' of the plunger?? --
per your statement "I just can't seem to get the needles back home in time, before the plunger comes forward enough to hit the stop" --
Question is: Is the plunger hitting the stop on the return to the front of the baler, stroke & continuing to travel? or is it hitting the stop on the compression (towards the needles) stroke, & coming to an abrupt stop of travel, shutting the whole baler down?
ie..... ...(per an 'in time' machine)...
bale length wheel decides there is enough hay in the chamber for a 'bale' & 'trips' the knotter mechanism (or manually done by rotating the meter wheel or pulling the trip lever)...components of the knotter begin to move as soon as the plunger has completed its current stroke & has reached the precise 'timed' location in the next 'compression' stroke (where the plunger has compressed the hay, past the dogs, & is in postion for the needles to travel upwards through the slots in the face of the plunger without restriction of hay on either side of the needles), as soon as this 'precise timed location' of the plunger has been achieved, the needle carriage is released & driven (very quickly)by the knotter mechanism, & in doing so -- as soon as the needle carriage begins to move..... .the plunger stop enters the bale chamber.....which the plunger will make contact with on its way back to the front of the baler -- it is spring loaded & constructed so that the plunger can push/slide it out of the way on the return stroke, but the spring will pull it back into place as soon as the plunger passes. As the knotter & needles complete their duty & return to 'home', the plunger stop is pulled out of the chamber to allow the plunger to go past on its next compression stroke. If the 'timing' is not right....the stop will still be in the chamber to stop the plunger on the next compression stroke to protect the needles, as the needles are not back in home position & out of harms way..... .
Hope this has helped define/clarify a little..
Garry
Another thought -- glc
09-25-2003 23:36:48
 Re: Re: Re: Re: I need help again in reply to Garry, 09-25-2003 22:47:28
Bill,
I'm not at all familiar with the 24t, or any balers other than the 2 that I have, but from an assumption point of view..... ....as for the connecting rod between the needle carriage & plunger stop.....
I would think that there would be some 'bend' in the rod.....(assuming it connects similiar to the way the 273 & 542 does)... my reasoning -- attatchment to needle carriage is (just guessing) probably 10 - 12 inches more/less below the attachment point on the plunger stop..... without an 'offset' bend or joint of some type in the linkage, true horizontal movement (in relationship to the movement of the needle carriage) to actuate the stop would be comprimised with a 'straight' rod or bar, as it would be traveling at an upward angle to the bale chamber rather than parallel front(in) to back (out)movement.....
Hopefully another 24t owner will join in to give you an exact answer..... if'n not & your owner's/operator manual doesn't give you a picture, stop in at your JD dealership & ask them if they can print the parts diagrams for it (they can 'if' they will..). Maynot be exact, but should give you a general idea of original shape/assembly.
Garry
Bill in NE Texas
09-26-2003 17:05:25
 Re: Re: Re: Re: Re: I need help again in reply to Another thought -- glc, 09-25-2003 23:36:48
Thanks to all of you for your input to my plunger stop challenge. It was in the knotter drive timing. Although, it is not in time as called for in the book. I kept adjusting untill it fell in right. I attempted to bale with it for the first time today. I need to do some adjusting on the right knotter assembly as the twine is being cut before the knot. That should not be a problem. It looks like it is going to form some nice bales. Thanks again for all of the response to my challenge. Bill
PS; I asked earlier if needles for a wire tie could be used on a twine tie. Evidently they can.
Bill
09-27-2003 03:54:31
 Re: Re: Re: Re: Re: Re: I need help again in reply to Bill in NE Texas, 09-26-2003 17:05:25
Good deal. Glad you are getting that thing going. I have read that the 24t makes some really tight brick looking bales. Let us know how it works out.
Bill
