IH 990 haybine
norbert kanzler
09-23-2003 19:06:41
I just purchased a used IH haybine model 990
The guard for the belt is missing. Dealer can not get. does anyone have a picture or drawing of one. I will make one if I know what it is supposed to look like
Robert Cornell
09-24-2003 17:43:46
 Re: IH 990 haybine in reply to norbert kanzler, 09-23-2003 19:06:41
While I know the safety guru's out there will probably chastise me for this....why do you need it? I bought a 990 last year and have cut almost 100 acres of hay with it missing the guard. I have had no problem with anything getting in the belt area so far...I spent my money and time rebuilding the cutting head....it works great behind my H....in 3rd gear even....If you are trying to put it back to original.....I wish I could help you, but I think you can get a manual from IH....probably a picture in there....
norbert kanzler
09-26-2003 18:38:23
 Re: Re: IH 990 haybine in reply to Robert Cornell, 09-24-2003 17:43:46
got both the operators manual and repair manual. Pictures of shield (guard0 are not very good.
I do not want to put back to rigional conidition only want it to work good. Right now the hay builds up on the belt that runs the cutter bar. I wanted to prevent this
Steve
09-27-2003 18:24:18
 Re: Re: Re: IH 990 haybine in reply to norbert kanzler, 09-26-2003 18:38:23
Norbert,
Are you talking about the guard that goes under the sickle drive belt?
norbert kanzler
09-30-2003 13:22:27
 Re: Re: Re: Re: IH 990 haybine in reply to Steve, 09-27-2003 18:24:18
Yes. It is called a guard one place in the repair maNUAL and guard another. It is missing. Haybine works OK but hay builds up on the drive belt. I would like to install a guard (or shield) before next year. I m done for this year. Thanks for any help you can give
