Implement Tires
Bill
09-23-2003 12:07:34
I gather that a lot of older implements, like a baler and older tractor (front end) used bias plied tires that were 6.00 x 15 and 6.00 x 16, etc. What are you folks replacing these with? Anyone using metric sized radials?
Again, just courious, thanks in advance,
Bill
MH444LP
09-23-2003 21:17:20
 Re: Implement Tires in reply to Bill, 09-23-2003 12:07:34
Yep, we use up our old radials on the plows, mowers and wagons. They can take more abuse in the heavy stubble and brush it seems like.
Nebraska Cowman
09-23-2003 18:07:54
I replace with rib implement tires. yes you can still buy them.
paul
09-23-2003 13:42:44
A lot of old car & truck tires get used, put a tube in & good to go.
For a tractor in dirt a new tri-rib would be better, if you have the $45.
--->Paul
sparky
09-30-2003 10:56:55
 Re: Re: Implement Tires in reply to paul, 09-23-2003 13:42:44
Having trouble keeping tires on a brush hog it was recommended I go to a shop about 30 miles from here that has used aircraft tires. I was told these are 14??16?? ply tires and would never have to worry about a flat again. Had planned on looking into this for next season when I was in the area. Currious if anyone had heard the same? Dan
