float control
B. Lester
09-19-2003 11:00:45
i use a woods finish mower and 5 ft bushhog with a ford 600. chain kits are used on each for height adjustment. Any better suggestions and where is float control lever? thank you
paul
09-20-2003 00:13:33
 Re: float control in reply to B. Lester, 09-19-2003 11:00:45
Ford 3pt only has float - no down pressure.
Are you asking about the position/ draft control? For most of us 'draft' is only useful for mounted plows or other heavy loads - needs to compress that big spring on the upper link to do anything -, altho some experiment with lighter stuff it really wasn't intended for such. 'Position' is what works for all your uses.
Should be a lever under your right thigh as you sit on the seat - altho I haven't looked at a 600 exactly.
Wheels or chains for height control.
--->Paul
