The broadcast seeder will work. The drill with grass seeder will work better. That is what I use. Normally we seed oats at 3 bu per acre. With alfalfa I seed it 2 bu per acre & harvest the oats for grain. If you wish to cut it for hay I guess you can go as low as a bu, altho some drills have a hard time metering out at less than a bu.... The alfalfa you want in 1/4 - 1/2" of dirt - good firm dirt - work it right before hand, so the dirt is firm but quite fine on the surface. Do NOT seed the alfalfa into the oats trenches. You want it on top of the ground. Then follow your drill (or spreader) with a packer if you can get your hands on one, or a harrow (drag) set real angled - not much tooth. Might want to go over 2 times with that. Alfalfa seed wants to be in _very_ shallow, in very firm ground, and get moisture fairly soon. Now, the difficult part - calibrating the drill (or spreader)! Anything with any wear on it you really won't be able to go by the number chart - those alfalfa seeds are so tiny, any little variation in the linkage will double or 1/2 the rate you were aiming for. The good news is that doubling the alfalfa rate won't hurt anything but your pocketbook. ;) --->Paul
