Help with IHC feed grinder
Jared
09-14-2003 19:29:51
i have a ihc belt driven feed grinder. i would like to grind corn with it, can i do this?
JMS/MN
09-15-2003 07:48:51
 Re: Help with IHC feed grinder in reply to Jared, 09-14-2003 19:29:51
Since it is belt driven, I assume it has to be anchored to the floor of the granary, right? It could be either a hammermill or a burr mill. A hammermill will have flat knives mounted on a rotating shaft assembly, and a screen with many holes that the feed is forced through. A burr mill has a round bowl-like portion at the base of the hopper, which is where the grinding happens, and the feed is discharged through a chute at the bottom of the bowl. Fineness of grind is varied by turning handwheels. Either can grind shelled or cob corn, but I think the burr mill is pretty slow with cob corn.
jarry
09-15-2003 15:36:21
 Re: Re: Help with IHC feed grinder in reply to JMS/MN, 09-15-2003 07:48:51
it is a burr mill that has two beater type things that has a bar inbetween them that sits ontop of the bowl portion. then the feed is forced into a grindstone then out the shute am i right?
paul
09-15-2003 05:08:02
1. What model are we talking about, I'll assume an older grinder, but have heard newer grinder/mixers called that too. What screens do you have?
2. What do you mean by corn, shell corn or ear corn?
--->Paul
