JD 214T Bale Ejector
Dan
07-01-1999 20:48:30
The manual for my JD 214T baler shows an optional JD No.2 bale ejector. I made a call about an ejector that was taken off of a JD 24T baler..can anyone tell me if that one would hook up to my 214T baler ? Would it also be a No.2 ? Thanks
Wrenchbender
07-01-1999 21:52:08
 Re: JD 214T Bale Ejector in reply to Dan, 07-01-1999 20:48:30
We have a 224T that had a bale ejector,it was driven by a PTO shaft.The shaft hooked up to the gear box that runs the knotter,the gear box has a splined shaft coming out the back.The ejector bolted to the bale chamber,it was a pretty simple setup.I would say if your gear box has the splined shaft and the bale chamber is the same size it should work.My 2 cents worth!
Dan
07-05-1999 20:52:38
 Re: Re: JD 214T Bale Ejector in reply to Wrenchbender, 07-01-1999 21:52:08
Thanks for the info..there is a splined shaft up in the knotter area...ok Thanks again
Tim(nj)
07-02-1999 15:52:16
Check that thrower well, because the #30 ejector was also available with pump, plumbing and adapter brackets to fit the 24T and 224T balers. It will not work, as far as I know, on a 14T or 214T. The #2 however, most likely can be fitted, as long as you can hook up the thrower drive shaft to the front of the baler somewhere.
Dan
07-05-1999 20:56:08
 Re: Re: Re: JD 214T Bale Ejector in reply to Tim(nj), 07-02-1999 15:52:16
Thanks, I'd better take some notes and maybe some
pictures of my 214T when I go look at this thrower
thanks again for your input
