jd 71 series flex planter?
jeff
09-11-2003 20:47:29
I ENDED UP GETING THE 71 SERIES FLEX PLANTER WITH
A 4 ROW SETUP. HAS A COUPLE SMALL HANDLE CASTINGS CRACKED THAT ADJUST SPRINGS. OTHER THEN THAT LOOKS GOOD. WHERE DO I BEGIN TO SET ALL THE ADJUSTMENTS ARE THERE MANUALS STILL AVAILABLE?
ALL 4 UNITS APPEAR TO BE SET TO DIFFERENT SETTINGS.
LOOKS LIKE A HEAVY UNIT SET UP FOR CAT 2 AND CAT 3
3PT HITCH. THANKS IN ADVANCE JEFF
Paul n OH
09-12-2003 04:03:43
 Re: jd 71 series flex planter? in reply to jeff, 09-11-2003 20:47:29
Yes, all manuals still available. It's still a current model.
I bought an owners and parts manual recently from Deere. I think it was maybe $75 or more for both but I felt it was worth it. They were especially helpful.
greenbeanman
09-11-2003 23:06:53
Gosh, I haven't owned Flex 71s since I sold out in 1982.
I was thinking however that there should be a decal chart inside of the pop off chain cover.
Be VERY careful if you have to plant on steep terraces. Any sideways sliding can break the aluminum casting. Welding them works readily though a pain.
