Need info on hydraulic cylinders for loaders
Mike Harris
07-01-1999 13:22:05
I've talked to a guy who has an old loader(commercially made out of pipe)for a small tractor like an 8N. He says it's in rough shape, but only wants $150 for it. If the cylinders (three of them) and the pump are shot, about how much would I have to pay for new ones. Does anybody have a source for loader hydraulics that would be available to me in California?
Would I be better of paying for a loader in better shape?
Mort
11-27-1999 10:45:58
 Re: Need info on hydraulic cylinders for loaders in reply to Mike Harris, 07-01-1999 13:22:05
Ever heard of an outfit called Sierra Hydraulics & Machine in Redwood Valley, CA? I have had really good luck with those guys. Good quality and a good price.
Mort
Dave
07-05-1999 19:37:51
Your best bet is at a good hydraulic shop. The cylinders can get new seals and new shafts if needed. Depending on length, be prepared to spend from 150 - 225 each cylinder for all new parts. I don't know what pump is on it, but figure another 300-325 if a new one is needed or can be obtained. Might have to fabricate something. Front loaders are great but not cheap.
Good luck
paul
07-05-1999 13:54:36
New hydraulics are expensive - _esp._ for anything other than standard 8" cylinders. Assuming the old is wore out, I'd grab a new pump, and try repairing the cylinders, that can be done cheaply. If the rod is pitted then I'd look to a surplus supply place, there's a good one in central USA I can't remember the name of it now... Some welding shops will replace the rod & seals for less than buying a whole cylinder would cost.
--->Paul
big fred
07-01-1999 14:36:39
Check out Northern Equipment. Follow link below to Website. Also, check out local farm equipment dealers and hydraulic repair shops in your area. You might get lucky and find some used cylinders.
