Are the bolts bolted in?
Peter
09-10-2003 13:33:57
Trying to change the blades on a SQ-60. Rented an impact wrench and got the nuts off but the bolts won't come out. Should they just drop out? Thanks.
peter
09-12-2003 13:55:26
 Re: Are the bolts bolted in? in reply to Peter, 09-10-2003 13:33:57
use some anti-sieze on the big bolts, I wirebrushed mine good before I put them back in and it helps
to keep the blade still, (turn off the engine first), set the pto in gear, use ground position if you have it
marlowe
09-10-2003 17:37:35
is a sq-60 a bushog? if so the bolts on mine have a notch on them to keep them from turning you have to drive them out with a big punch. becarful not to mess up the threads
Peter
09-10-2003 19:17:55
 Re: Re: Are the bolts bolted in? in reply to marlowe, 09-10-2003 17:37:35
Yes it is a Bush Hog and thanks. I found a local dealer and called. He told me the same. Was able to pound them out, get new blades mounted. Wish I could have keept the impact wrench. The boltes did not want to go back in easly. The nest time i am going to change one blade at a time. try holding the blade, stumpjumper in place while coxing a struben bolt. fun, fun. Thanks again.
