Ford 530 And JD24 Baler Parts.
Bill in NE Txas
09-07-2003 11:28:30
After buying a JD24t at auction yesterday I have found several things wrong with it.Now that"s not suprising. Font Drive chain behind clutch to tight; Needle carrier, Tube that goes around bottom of baler and attaches on both sides ,bent and torn on left side.Attaching bolt on left side bent ; both needles broke and hittig the crossbar under frame on the way up into the chamber: I believe that all of this was caused by the previous operator hitting something and doing the damage or someone ran into it. I looked at the componets on the JD very carefully and took some measurements. It appears that the entire needle assembly is the same. Also the knotter mechanism are the same except the hold down bolt portion.Am I right. I went to the John Deere web sight last night and tried to order a manual. The sight says not available. I will try the dealer Monday.
paul
09-07-2003 12:14:57
 Re: Ford 530 And JD24 Baler Parts. in reply to Bill in NE Txas, 09-07-2003 11:28:30
Sounds more like the previous owner didn't have the timing right. Become very familiar with that, and don't mess with the chains until you grasp the concept of 'timing'. That's where the manual will help you.
--->Paul
