Spreader Apron Chain Question
Kilian
09-03-2003 11:34:51
This may be a dumb question, but how difficult would it be to modify a T-bar apron chain to fit another spreader? I have an old spreader that may be beyond hope, but the T-bar chain is still good. If I find another spreader to use, the slats on the chain most likely won't fit (too wide). Has anyone shortened and re-riveted slats to work on a different spreader?
Also, will a T-bar apron chain work on most older (#67H) spreaders?
Thanks for the help.
Dick in Ore..
09-03-2003 16:11:59
 Re: Spreader Apron Chain Question in reply to Kilian, 09-03-2003 11:34:51
If the other spreader is narrower than your present apron, just cut a piece out of the middle of the T-bar or angle iron slat and reweld together again.. Grind the weld smooth on the bottom where it contacts the floor.
Dick
paul
09-03-2003 19:45:59
 Re: Re: Spreader Apron Chain Question in reply to Dick in Ore.., 09-03-2003 16:11:59
Welding + manure = rust-through. We all do it, but welding on manure parts often doesn't last.
Just as easy to cut one side off & redrill holes, put rivots in. Dad did on our spreader, he got a brand new web for $5 at an auction, but it was too wide.
--->Paul
Kilian
09-04-2003 07:30:48
 Re: Re: Re: Spreader Apron Chain Question in reply to paul, 09-03-2003 19:45:59
Thanks for the replies. Will a T-bar chain work in place of a 67H chain?
Dick in Ore..
09-03-2003 22:11:02
Good point Paul. Would it work to use stainless rod? Just a thought..
Dick
