WOW, thanks to you all for posting... Now i'll try to answer your comments. Thurlow, I'm trying to figure out what full time farming has to do with whether a rotavator works or not???? I guess i fail your test, because i do make quite a bit of $$$ off farm, rotavateing for others. I guess that could be considered "off farm income". Tom, You need to look again!! The stubble is there, but i did cut it short after combineing. I had a chance to sale all the straw, so i cut it as short as possible. Short stubble = more $$$$ for me!! Roy in UK, The only problem with plowing and dragging a gate is, i farm all organic. I normally spread turkey manure on my ground, and i like it tilled in a bit to not loose the "N". I've never been to the UK, so rotavators may not work well over there?? BUT, I do have pictures of a guy there rotavateing his ground, so i guess like here, some do use them. tim(in) Howard offers two styles of blades. One is "L" shaped, the other is "C" shape. I've tried many of each, and i honestly can't see any difference in how they work. There are two guys not far from here that bought two new 120" Howards. They rotavate all there corn ground with them. I'm told they have been useing Howard rotavators for many years now. Paul, I too have some heavy ground. I really like the way a rotavator gets me started planting eariler in the spring!! As for rocks, yes the field in the pict has had the rocks picked now for many, many years, so it looks "rock free", BUT IT ISN'T!!! What brand does you brother have???? Are you sure it's a "rotavator" OR a garden tiller????? ????? ? There's a HUGE difference there!!!! You said "shear pins" so that leads me to believe he has a cheap garden tiller!!!! Paul, where in my post did i say that i new everything, about "all locataions"??? OR, that a rotavator was for everyone??? I've posted many times here that they ARE NOT for every one!! Indydirtfarmer, again, are you talking about a tiller or a rotavator????? A rotavator will do anything a tiller will do, and MUCH MORE!! BUT, you are right, there's a right way and a wrong way to use every tool!! pudding, I assume your first comment was answering someone else and not me??? :>) There are times when a "crumbler roller" would be nice, and Howard does offer one."IF" i was doing a lot of corn ground, i'd get one!! Cliff, I think a rear "tiller" or a rotavator, either one would level your ground quite well. Just be willing to spend the $$ for a good one or you will be buying a lot of parts!! A "used" Howard HR30 80" can be bought in excelent condition for about $3,000.00. You can check them out at the addy: >Link >Link Tim (nj), Your right, i'm not in NJ, so i can't comment on how one would work there. BUT, rocks WILL NOT kill a rotavator!! (assumeing you have it sized right for your tractor hp, and the slip clutch is ajusted right) If you can plow it, it can be rotavated!! I rotavate heavy clay and very rocky fields quite often for others!! In fact, i'll be 50 miles north of here friday doing some very heavy clay ground. The guy has me at his farm several times a year to do his tillage. Man, and he has rocks!!! Tim, the amount of time your actually spend on a rock is so small, that it doesn't have time to do a lot of damage. Sure, if the rotor blade is already wore out, it sometimes WILL break it off!! BUT I've NEVER broken a blade that was in good condition to begin with. That doesn't mean it couldn't happen, but in over 15 years of custom work, and useing a rotavator on my farm, it hasn't happen to me! Dale, Read the above, rocks will NOT "smash" a Rotavator!!! I've hit probably hundreds of thousands of rocks over the years!!!! I incorporate a lot of turkey manure into my ground. I don't use any chem fert, or spray of any kind on my ground for weed control ect... By doing a little extra tillage, i can control the weeds, and how else would you apply turkey poop that's in dry sawdust???? Spread it on top, and loose all the "N"? Hugh MacKay, Millions of farmers???? Are there that many left???? :>) Is this like the bumper sticker i use to have on my truck?? It read, "Eat moose, 10,000 wolves can't be wrong!!" :>) My feelings are, lots of farmers still use plows, but not all. Lots of farmers are no till, but not all!!! Just because some do and some don't, doesn't mean anything to all the rest of us!!! How does Howard and Kuhn stay in business if they don't make a tool that works??? John, I'm not too sure what to say to a guy that has owned a rotavator for 25 years, and STILL doesn't know how to use it!!!! Does it have a multi speed gear box???? OR, is it a Howard garden tiller??? (I have one of those too) If it does have the multi speed gear box, have you ever considered what would happen if you increased your ground speed, opened the back door, and put the gear box in it's "slowest" speed???? Wouldn't that stop the "grinding it to powder" problem your haveing???? Come on John, learn how to use the tool!! Thanks again to all of you, for posting, but i'm still waiting for all those guys that keep recomending "plowing" "discing" and "disking" some more and "draging a piece of metal or chain" to those that have some tough ground to work up!!! Every time i answer, "get it rotavated" there's always some one telling me rotavators are "too slow", "use too much fuel", "too fragile" and "grind the ground to powder"!!! LEARN to use the tool, and you "won't" have those problems!!! Robert
