potato ridger ideas
mike
09-01-2003 15:40:49
guy up the road stopped by and asked if i could build him a potato ridger to be pulled with a 8-n ford, i have a couple of ideas but someone out there probably has a better one. he said he likes his hills to just clear the bottom of the tractor.thanks for any ideas... mike
Tom A
09-02-2003 02:52:38
 Re: potato ridger ideas in reply to mike , 09-01-2003 15:40:49
I use 2 different implements, but have always thought about building a single one to do all.
I lay out my rows with a deep pass using a middlebuster with a fairly wide sweep. This give me a fairly deep planting trench with loose soil hilled on each side of it. I plant in the bottom of this.
The I make a pass with a cultivator set so the middle pair of teeth just throw the soil from the edges back in to the trench. A few weeks later I make another pass with the teeth set so they hill a little more, but I'd always figured if I put wider sweeps on the ends they'd hill even more than they do.
So if you make an implement with 3 shanks, and the middle one is either removable or else swings up out of the way, then you can do all this...and if you get a wide shovel-blade like an old-time potato plow it would harvest, too!
just my thoughts,
tom
wh
09-01-2003 17:39:01
get a pair of disc hillers (agri-supply) either 14 or 16 inch. build a frame to attach them to and go. agri-supply is on internet - good prices/company. wade
