MF #10 baler slip clutch slipping
Brian
09-01-2003 14:12:47
I believe that my slip clutch on my baler is about worn out. when I try to start the baler(empty)from a stand-still I have to very easily ease off the tractor clutch to prevent the baler from slipping. after slipping several times the baler finnaly gets up to speed. while baling, if I pick-up to much hay the clutch will start to slip periodically untill the fedder house is empty. I have tightened the springs up as much as they will tighten. any other suggestions? how much will a new (or reman.) one cost? it looks like an expensive part. thanks for any help
Rob
09-01-2003 16:48:45
 Re: MF #10 baler slip clutch slipping in reply to Brian, 09-01-2003 14:12:47
I've had to change this out on my MF 12 in the past. You might be surprised when you price them out - they're not that much $. If you can't find them (there's 2) locally, I can give the name of a Dealer up here who has them. What kind of shape are the bolts and springs in? They've been known to get used with a bar (have done it myself on occasion - NOT reccommended practice) to manually turn the plunger and might be a little rough. It's a pretty light clutch they used but back in those days most tractors didn't have the kind of pto torque and h.p. like now.
