John Deere 24 T Baler
Dan Z.
08-30-2003 16:34:37
Can the hay pickup apparatus(auger etc.)be replaced with parts from the older 14 T Baler? Someone out there must still be using one of these old balers. Thanks.
Tom Smith
09-03-2003 18:52:26
 Re: John Deere 24 T Baler in reply to Dan Z., 08-30-2003 16:34:37
Dan, you shouldn't have any trouble useing the feed auger assembly from a 14T on a 24T or the other way around.they are driven by the same shaft. as for the model numbers the 214 and the 224 were heavy duty models I have 3 14Ts and a 214T.
the 214 has a 16" wheel on the flywheel side and the flywheel weights a good bit more too.knotter frames won't interchange between the 24 series and the 14s because of the needle lift drive assy. Tom in N.E.Ga.
Brent in IA
09-02-2003 04:23:55
The 14T isn't really older than the 24T, both were made at the same time. Then JD moved to the 214T and 224T, again at about the same time. I have a 214T baler that I use and a 14T I use for parts, they are nearly identical. But I have a friend with a 24T and he needed a part so he came to look at my 14T and they were vastly different. We never compared pickup heads, but the 24T is higher capacity than a 14T so the head may be wider?
Rob
09-01-2003 18:44:33
There's likely lots of us. Hey, "Nothing runs ..."
I don't know as I've no way of comparing the two. Try doing a search on "JD 14 or JD 24" on the home page of YT and see what u get. A dealer might be able to cross reference part numbers for u. Good luck with it.
